3CX in Docker container behind nginx-proxy with letsencrypt
Discussion in '3CX Phone System - General' started by Bret Gordon, Sep 7, 2017.
Tags:
  1. Bret Gordon
    Jun 16, 2017
    24
    Has anyone tried this? I've searched around, but I haven't found anything.
    It should be fairly straightforward to set up a Dockerfile that pulls from Debian 8 and loads up 3CX, so the real challenge will be setting up the nginx reverse-proxy. I'll start playing around with it, but any suggestions are greatly appreciated.
    If anyone has 3CX running behind an nginx reverse-proxy, I would LOVE to see your config!
    I'll post a docker-compose.yml file here if/when I ever get this going properly. :)
    For starters, here's my standard docker-compose.yml for nginx-proxy/letsencrypt. Note that there is no "networks" config -- it will create "nginx_default" (i put it in a folder named "nginx") that you attach other containers to behind it:
    Code:
    version: '2'
    services:
      nginx-proxy:
        image: jwilder/nginx-proxy
        container_name: nginx-proxy
        ports:
          - "80:80"
          - "443:443"
        volumes:
          - ./vhost.d:/etc/nginx/vhost.d
          - /usr/share/nginx/html
          - ./certs:/etc/nginx/certs:ro
          - ./conf.d/:/etc/nginx/conf.d
          - /var/run/docker.sock:/tmp/docker.sock:ro
        restart: always
      letsencrypt-nginx-proxy-companion:
        image: jrcs/letsencrypt-nginx-proxy-companion
        container_name: letsencrypt-nginx-proxy-companion
        volumes_from:
          - nginx-proxy
        volumes:
          - /var/run/docker.sock:/var/run/docker.sock:ro
          - ./certs:/etc/nginx/certs:rw
        restart: always
    For example, a Wordpress container connected to the proxy:
    Code:
    version: '2'
    services:
      db-wordpress:
        image: mysql:5.7
        container_name: db-wordpress
        volumes:
          - ./db-wordpress:/var/lib/mysql
        environment:
          - MYSQL_ROOT_PASSWORD=wordpress
          - MYSQL_DATABASE=wordpress
          - MYSQL_USER=wordpress
          - MYSQL_PASSWORD=wordpress
        networks:
          - proxy-tier
        restart: always
      wordpress:
        depends_on:
          - db-wordpress
        image: wordpress
        container_name: wordpress
        volumes:
          - ./html:/var/www/html
        environment:
          - WORDPRESS_DB_HOST=db-wordpress:3306
          - WORDPRESS_DB_PASSWORD=wordpress
          - WORDPRESS_DB_USER=wordpress
          - VIRTUAL_HOST=example.com,www.example.com
          - LETSENCRYPT_HOST=example.com,www.example.com
          - LETSENCRYPT_EMAIL=admin@example.com
        networks:
          - proxy-tier
        restart: always
    networks:
      proxy-tier:
        external:
    There REALLY shouldn't be any reason why this won't work! Like I said, I think it is just a matter of getting a proper reverse-proxy config file set up.
  2. Bret Gordon
    Jun 16, 2017
    24
    NOBODY??? Guess I have to do everything myself, lol :rolleyes:
  3. eits
    Sep 18, 2017
    hi bret, any success so far? i got that question from a future customer today...
  4. Bret Gordon
    Jun 16, 2017
    24
    I haven't had a chance to get into it yet, unfortunately. I just bought a refurb R900 where it will eventually live, but I'm having issues with the CPU's overheating and a stick of bad RAM somewhere. So I need to take care of that first.
    Like I said, though, the trick is going to be in the proxy config, so I'll start looking to see how people might be doing it with other PBX's and go from there. I really don't see any reason why it wouldn't work.
