3CX in LXC?
Discussion in '3CX Phone System - General' started by coreybrett81, Apr 25, 2017.
  1. coreybrett81
    Nov 11, 2016
    54
    8
    Can 3CX be installed inside an LXC container?
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello coreybrett81,
    Please read the following information regarding 3CX on Linux:
    Supported VM Platforms
    3CX Phone System is extensively tested to be run as a VM which eliminates the cost of separate hardware and adds high availability solutions based on the hypervisor infrastructure. Tested and supported hypervisor platforms are:
    • VMware ESX 5.X and above.
    • Microsoft HyperV 2008 R2 and above. See our Hyper-V Page for the specific settings for running 3CX.
    • KVM
    • Citrix XenServer 7.0 and above
    • Amazon AWS
    • Google Cloud Engine Instance
    Avoid using 3CX Phone System on converted VMs (P2V) because a converted virtual machine might have timing issues, which causes the guest operating system not to sync with the timer of the hypervisor.
