- Joined
- Jan 26, 2008
- Messages
- 19
- Reaction score
- 0
I have a grandstream 4104 VOIP Gateway, 3cx installed in windows 2003 server, and using a 3cx client. I have followed the instructions to set up 3cx and the gateway, but the call gets terminated when i call out. I am just using straight VOIP Analog Gateway with a PSTN Line so I dont think I will have problems with firewall settings to do outgoing calls right? I can receive calls but not do outgoing. Any resolution is greatly appreciated.
This is the Server Log:
17:20:00.437 Call::Terminate [CM503008]: Call(26): Call is terminated
17:19:44.015 CallCtrl:nLegConnected [CM503007]: Call(26): Device joined: sip:[email protected]:5060
17:19:44.000 CallCtrl:nLegConnected [CM503007]: Call(26): Device joined: sip:[email protected]:5070;rinstance=be73a0101052427c
17:19:43.984 Line:rintEndpointInfo [CM505002]: Gateway:[PSTN1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:8) 1.0.0.55] Transport: [sip:192.168.0.10:5060]
17:19:43.890 CallCtrl:nSelectRouteReq [CM503004]: Call(26): Calling: PSTNline:10000@[Dev:sip:[email protected]:5060]
17:19:43.828 CallCtrl:nIncomingCall [CM503001]: Call(26): Incoming call from Ext.102 to [sip:[email protected]:5060]
