3CX in Windows event viewer
Discussion in '3CX Phone System - General' started by Paddyd, Jul 30, 2013.
  1. Paddyd
    Jul 19, 2013
    9
    I wish to make use of the windows event viewer to send an email when the 3CX has a problem. Trouble is I do not have a list of the numbered events that 3CX can generate. As I have had the main SIP trunk go up and down I have the events for these and there is a nice wizard to turn an alarm into an event trigger. This only works if you already have had that fault.
    I do not what to "wreck" an installation just to get a fine set of numbers, is there a list around at all?
    Failing which could this thread be used to "collect" the major alarms. A given extension failing to register or a caller hanging up before talking might not make the list but I sure there are other things you like like to be aware of before the customer!
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    A search of the blog shows:
    http://www.3cx.com/blog/docs/list-of-events-generated-by-3cx-phone-system/
  3. Paddyd
    Jul 19, 2013
    9
    My most humble apologies, I did a search but this thread did not come up!!
    just what I was after, Many thanks
