3cx Inbound Calls - Show Queue/Group
Discussion in '3CX Phone System - General' started by Joshua Stump, Mar 9, 2017.
  1. Joshua Stump
    Mar 9, 2017
    10
    Just switched to 3CX from cloud hosted solutions so be gentle if this is something easy I'm missing...
    I would like to have caller ID show the Queue or Ring Group when calls come in to those areas, but calls that are direct to extensions, I would like to remove the Inbound Rule name.
    I found the option under Contacts - Options to disable all, but I still want to keep the Queue or Ring Group names if possible. Anyone?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,321
    252
    Not at this time... I would like the same.
    All you could do is remove the name from the DID.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    In fact that is the solution, just remove the name from the inbound rule
    Joshua Stump likes this.
