3CX Install Port 5060 udp
Discussion in '3CX Phone System - General' started by MB1, Jun 24, 2010.
  1. MB1
    MB1
    Nov 2, 2007
    39
    Hi All,
    Just installed 3CX 8.0.10824.716 on Server 2003 SP2 but cannot get port 5060 udp to open (5060 tcp works). I have uninstalled all virus/firewall software and windows firewall is turned off. This is a fresh install of Server 2003 and the only other software running is an email server(Icewarp). I scanned the port using Netinfo from both within the server and from an external system located on the same LAN.
    Thanks.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    As i see, ICEWARP uses port 5060 as well.
    You would somehow have to disable the VoIP options for Icewarp if possible before installing 3CX.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
