3cx installation on Debian
Discussion in '3CX Phone System - General' started by Saniel, Dec 20, 2016.
Tags:
  1. Saniel
    Dec 20, 2016
    I want install 3cx on Debian 8 with my own FQDN, but on FQDN Configure step i just can't choose this parameter in both of installations (web and console). DNS are already configured and Lets Enrypt process completed. Maybe someone encountered with this problem and can share the solution.
    Thanks.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,380
    535
    Hi there,
    If you have used your key with a different FQDN in the past then you need to release it before you can choose a different FQDN. Also PBX edition keys do not give you the option to use your own FQDN.
  3. Saniel
    Dec 20, 2016
    Ok, thanks.
  4. SimWhite
    Dec 19, 2016
    17
    OK, could you tell how can I use generated LE SSL certificate for the TLS connection on port 5061?
  5. StefanW
    Jun 2, 2009
    1,222
    93
