3cx Installation
Discussion in '3CX Phone System - General' started by AndreasMetal, Feb 17, 2008.
  1. AndreasMetal
    Nov 16, 2007
    62
    Hello.
    I have a question.
    We are 5 persons located in other places, in greece.
    We want to do a 3CX Installation to answer calls all the stuff
    We are a "Group" and we want to have a call center.
    And sorry for the very very very bad english :oops:
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    yes you can have external extensions for the 5 persons in diferent locations
    cheers
  3. AndreasMetal
    Nov 16, 2007
    62
    And how can I set them to works in other locations?
    And..can I do it with the free version?
  4. AndreasMetal
    Nov 16, 2007
    62
    We are group of 5 friends, that offers some free internet services and we want to have one telephone support.
    But we haven't offices etc. We work at our houses and we wan't "to be connected" with a pbx. To answer calls anybody and transfer it to another person. We want use a "free" VoIP service such ..VoipBuster.
    Can we do all that stuff free with the 3cx free PBX version?
    And ..we want use 3CX Excellent Voip Phone or X-Lite.
    Thanks ;)
    I am waiting for an answer!
  5. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hi
    in 3CX you will define an extension for each person and in each location open the port 5060 and configure your phone the 3CX pbx address, extension number and password
    you can find aditional in at http://www.3cx.com/support/ in General 3CX Phone System FAQs
    regards
  6. aguilar
    aguilar New Member
    Jul 19, 2007
    169
  7. AndreasMetal
    Nov 16, 2007
    62
    Thanks a lot!
    And..can I use 3cx with VoipBuster..
    Thaaaaaaanks :roll: :)
  8. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    SUUUUUUUUUUURE!!!
  9. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    yes no problem with voipbuster
  10. AndreasMetal
    Nov 16, 2007
    62
    Now, I am sure..
    3CX IS SUPER AND HAS SUPER SUPPORT
    ..but ..what should I type in number field in 3cx VOIP Registration.
    Congrats :D :D :D :D :D
    And..is there anyway to do a bridge within 3cx and skype ?
  11. AndreasMetal
    Nov 16, 2007
    62
    ah....
    i can't install 3CX. It popups a message, that writes: "There is a problem with this Windows Installer Package. A program required for this install to complete could not be run. Contact your support personnel or package vendor.
  12. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Try running the package as you download it instead of downloading the package to your Hard Drive then running it.
    Stephen
  13. AndreasMetal
    Nov 16, 2007
    62
    it doesn't works :cry:
  14. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    wich windows version are you using?
  15. AndreasMetal
    Nov 16, 2007
    62
    Windows Vista Home Premium..
    my pc is a Intel Core 2 Quad,
    with 2gb RAM,
    512gb graphics card..
    but it doesn't works :cry:
    In anyway, thanks for answering :roll:
  16. AndreasMetal
    Nov 16, 2007
    62
    It's a little bit important :cry:
    Thanks :roll:
  17. matthijsolislagers
    matthijsolislagers New Member
    140
    At what point of the installation do you get the message?
    The error is an InstallShield error code. It indicates that the installation process has failed. The exact reason for this error is not known at this time.
    If the message appears after you selected the installation directory you could change it to another directory, sometimes that works because some traces of the installation are still available (also in reg so removing the dir doesn't work).
    If that doesn't work, try installing all latest updates from Microsoft.
  18. AndreasMetal
    Nov 16, 2007
    62
    Thanks for answering..
    I will try these things.
    This message pop-ups at the finish of the installation :?
  19. AndreasMetal
    Nov 16, 2007
    62
    Argh :evil:
    I have download all the latest important and no important updates, I change the location but nothing seems to works :cry:
  20. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    search at microsoft for Windows Installer Package
