3CX Installation
Discussion in '3CX Phone System - General' started by Ravilla, Jan 9, 2018.
  1. Ravilla
    Oct 4, 2017
    64
    Hi All,
    Could you tell me if it is possible to install 3CX without FQDN?
    i don't have FQDN and i don't want to use 3CX FQDN.
    can i put only the ip address?
    thanks in advance.
  2. eddv123
    eddv123 Active Member
    Aug 15, 2017
    914
    139
    Hi Ravilla,
    As part of the installation process an FQDN is mandatory, you have to have one. A 3CX FQDN is no trouble to configure so go with one of those.
    Having an FQDN offers many benefits.
    FYI: You must stay in valid maintenance to keep your FQDN live also.
  3. Ravilla
    Oct 4, 2017
    64
    Hi Eddv123,
    Thanks for your advise.
    if my maintenance license expired it cost 3CX show only error certificate or i cannot use the system anymore?
  4. eddv123
    Aug 15, 2017
    914
    139
  5. accentlogic
    accentlogic New Member
    Nov 14, 2013
    161
    66
    If your maintenance is expired, and you have a perpetual license key, you can still use the system. However, you would need to provide and maintain your own FQDN and SSL certificate.
    It may be possible to run 3CX in some configurations without an FQDN, such as when using a local VoIP gateway and no SIP trunks or remote extensions.
    NickD_3CX likes this.
