3CX Instance
Discussion in '3CX Phone System - General' started by spring, Feb 2, 2017.
  1. spring
    Nov 20, 2014
    53
    Hi, Could anyone tell me if i have one 3CX server with 3 instance so how can each instance connect to ISDN line?
    Thanks,
    Spring
    11,078
    324
    Define "instance". What type of ISDN, BRI, PRI?
  3. spring
    Nov 20, 2014
    53
    Hi Leejor,
    It can be FXO, PRI...ect.
  4. leejor
    11,078
    324
    Are you asking about a 3CX multi-tenant server attempting to access the same ISDN gateway/trunk group?
  5. spring
    Nov 20, 2014
    53
    Hi, Leejor,
    The purpose is to have one server with 3 or 4 companies then each company i want to know how they can connect to land line, FXO or E1?
    Do i need to use 1 gateway for 1 company or 1 gateway for all? how this should be done?
  6. leejor
    11,078
    324
    It depends. If you are planning on using the 3CX multi-tenant installation, then unfortunately, each tenant makes use of a different set of ports. That would make it difficult for multiple companies to share the same gateway. If this will be one instance of the 3CX server hosting more than one company, each with their own PSTN number, then that could be done, possibly awkward, but possible.
    You would probably want each customer to have their own trunk group for incoming and outgoing calls, so finding a gateway that doesn't force you to configure all PSTN lines into one group. would be needed.
    Look for a gateway that allowed the trunks to be broken into smaller groups, or accessed individually. Some gateways allow this through assignment of a different port to each PSTN line. Some make use of a unique prefix to specify which PSTN line to use.
  7. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    News flash:
    Customers are in no way affected by what happens on other PBX instances
