3CX Instant Emergency Response System
Discussion in '3CX Phone System - General' started by ciscotech2007, Mar 20, 2009.
  1. ciscotech2007
    Jan 27, 2009
    94
    Imagine if you will.
    An emergency event occurs, the server is down, the company production is down, there is a temporary customer event requiring staffing at an offsite location. How do you communicate with your team? What system can be setup quickly to be able to enable your team communications while not requiring expensive infrastructure?
    Typically during a emergency situation many different groups create a 'base' of operations where all have cell phones. Landlines are not available at emergency sites and intercommunication of the emergency response team is crippled and archaic at best. Running around the site or sites, calling one contact to get another contacts information and forget about sharing information or findings or resources.
    Enter; a hybrid setup of 3CX |Instant Emergency Response System.
    You team enters onsite
    Powers on your 3CX server notebook, PoE switch and PoE access points
    Distribute and Power up IP hardphone endpoints with wireless bridges
    Full IP PBX ready and running enabling your team to communicate as efficiently as if they were sitting back in their office.
    Without any wires to run, tie-down, step on or stumble over. ;)
    [​IMG]
    I have my Instant Emergency Response system up and running.... it surely turns some heads on projects. Anyone have any questions or suggestions on how to make this system better let me know.
  2. ciscotech2007
    Jan 27, 2009
    94
    Note: HSRP running between routers
    Note: Floating routes on routers, 5 second failover, primary comes up switches back to primary
    Note: Windows Server running minimum roles (AD, DHCP)
    Note: Windows Server running Exchange 2007 UM
  3. ciscotech2007
    Jan 27, 2009
    94
    Note: Windows Running SharePoint 2007 SP1 for team communications and web-applications
