3CX integrated with Polycom video
Discussion in '3CX Phone System - General' started by cpickering, Mar 26, 2013.
  1. cpickering
    Mar 25, 2013
    I was curious if anyone has a success story using 3CX with Polycom DMA to allow voice users to access video meeting rooms.
    Has anyone tested and verified the ability to build a SIP trunk to DMA and then dial into a virtual meeting room?
    Thanks for your input!
  2. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I have used the polycom vvx phones and the video works. We use lifesize video conferencing, I have not tried initiating a sip call from my vvx or softphone to the lifesize system. If I get some free time I will try to get it working.
