3cx integration with Avaya ip office 500
Discussion in '3CX Phone System - General' started by Fulail, Jan 15, 2018.
  1. Fulail
    May 28, 2017
    Is there any way to integrate 3cx with avaya ip office 500 ?
    i am using 3cx version 12. Can anyone tell me step by step guid to configure this ?
    Because i have a HO which is using 3CX and branch office using AVAYA. it's already running offices, so it's not possible to change existing systems.
    any help is highly appreciated.
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Topic has been discussed several times. Search for it.
    Generally you need a bridge or sip trunk in 3CX and sip trunk in Avaya without registration, DID numbers to route calls to extensions.
  3. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,218
    174
    mtech1 likes this.
  4. mtech1
    Jan 25, 2010
    28
    5
    I used a SIP trunk on both sides and outgoing rules on the 3cx and short codes on the IP Office works well. Getting the CLI and CLIP can be annoying but once you marry up the fields it’s bomb proof
    eddv123 likes this.
  5. VPCIII
    Feb 6, 2018
    9
    Hey, Edv123,
    Can you give me some details on the Avaya side settings....
    I would like to set up one extension on the 3CX system, run it over fiber point to point to our other office, Avaya system...
  6. eddv123
    Aug 15, 2017
    1,218
    174
    Hi VPCIII,
    I will send all the information I have over to you via PM.
