3CX Integration with InfusionSoft
Discussion in 'Ideas' started by aj.shaw, Sep 22, 2016.
  1. aj.shaw
    Sep 22, 2016
    With this push to integrate 3CX with various CRMs out there. May I suggest an integration with Infusionsoft?
    Usage case: Identical to how your other integrations work
    You already support CRMs with a smaller customer base than Infusionsoft.
    Apologies if this is the wrong forum to request this integration but I didn't see where else to put it and the 3CX CRM Integration Suggestion Form looked like it was aimed at developers or consultants of the actual CRM.
  2. aj.shaw
    Sep 22, 2016
    That's definitely an option but it's also incredibly pricey.
  3. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
  4. aj.shaw
    Sep 22, 2016
