3CX integration with salesforce plugin customized
Benson hunag
Hi Experts, I have setup the 3CX salesforce plugin successfully. It really do a good job for operation performance. How to customized the plugin? Where to download the plugin source code? Is it a open source? I want to customized more function for integration with salesforce. Thanks a lot.
Hello @Benson hunag,
The sources are located in the 3CX server, into a ZIP file:
- Windows: C:\ProgramData\3CX\Instance1\Data\Http\Interface\MyPhone\Integration\Salesforce.zip
- Linux: /var/lib/3cxpbx/Instance1/Data/Http/Interface/MyPhone/Integration/Salesforce.zip
If you want to make changes, rename it to "Salesforce_custom" for example, edit the C# code inside the ZIP, make the ZIP again with the same structure, and you will be able to select it from the console.
Kind regards.
Thanks, I have used to modify this ZIP file. It can work..By the way, I want to activate the salesforce call center in service cloud. It needs to configure some parameter ex. CTI Adapter URL. What is the URL for 3CX? It seems not be the user webclient.
call_center_d315_1071-jpg.7343
3CX doesn't use the CTI adapter. The configuration is only done on the 3CX side as explained in the documentation. No other configuration is needed.
@Benson hunag What customisation were you able to do with the integration?
Getting Started - Admin
TLK
Get 3CX - Absolutely Free!
3CX
