3CX Interface Error
Discussion in '3CX Phone System - General' started by LAFitz, Jan 4, 2010.
  1. LAFitz
    Jan 4, 2010
    I have just installed 3CX and attempted to enter the 3CX Interface, but get the following error: An exception occurred LoginForm Error: Config.server is not connected. Have I done something wrong?
    Laurie
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi Laurie,
    http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
  3. LAFitz
    Jan 4, 2010
    And now I have a second problem...this time with the 3CX Assistant that repeatedly gives me the error in the image below. Unfortunately, I am unable to access its control panel since I also cannot access the Management Console to enter the license key. If someone can tell me how to remove the whole thing from my computer to try again, I would be thankful. Add/Remove programs doesn't do it.
    Laurie
