3CX INTERFACE
Discussion in 'Windows' started by mani.sarathy, May 3, 2014.
  1. mani.sarathy
    May 3, 2014
    Hi, This is ManiP from India> I would like to know if I can interface to 3CX via a custom web application, and control the answering and making of calls and get the details of caller ID and other relevant data?
  2. roland_3CX
    roland_3CX Support Team
    Mar 28, 2014
    131
    7
    Hello ManiP,
    Yes you may use the HTTP API. Refer to the following link for additional information. http://www.3cx.com/blog/docs/3cx-http-api/
