3CX internal calls quieter than external calls
Discussion in '3CX Phone System - General' started by rhys100, May 12, 2017.
  1. rhys100
    Apr 7, 2017
    25
    Calls seem to be 30% quieter than external calls.
    I have set PBX delivers audio on all extensions, all extensions are set to PCMU as first priorty.
    We have a 200/200mb/s link with 2ms delay and all handsets are Yealink T48G
    Is there a way to increase volumn on internal or check why we are having this issue?
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @rhys100,
    You can check in the phone's web interface if there is an option to increase the microphone volume.
