3CX interoperate with H.323 Gateway
Discussion in '3CX Phone System - General' started by Wakky, Jun 26, 2007.
  1. Wakky
    Jun 25, 2007
    Hi there,
    I have a H.323 Gateway ( 2 FXS and 2 FXO - Planet VIP-400 ).
    Has anyway to interoperate with 3CX to access my lines??
    []'s
    Wakky
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    No, we're not going to support H.323. It's obsolete technology.
  3. Wakky
    Jun 25, 2007
    Ok... i read this.... but has some solution like a third party software to "translate/transform" sip in h.323 like a Gateway??
  4. Anonymous
    Anonymous Guest
    Where did you pick that up from?
  5. Wakky
    Jun 25, 2007
    Somebody told me about this kind of software... one of this is sip323. Rumors??? :cry:
  6. archie
    3CX Support
    Aug 18, 2006
    1,309
    It is not rumors, and I know that some works has been done in that directions, but I can not provide you with any pointers. The only thing I know is that Genesys Labs (USA) was developing kind of h323-sip gateway, but I'm not sure if they are successfull and selling it. In any case it couldn't be a free product. So it would be cheaper and wiser for you to buy SIP hardware.
  7. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    SIP <==> H323 already available at the market. But it's not a cheap solution.
    WellSC 5900 is a universal signal converter for H.323 and SIP. It not only provides simple SIP to H.323 conversion but also DTMF conversion. For H.323 users, it normally use H.245 for DTMF relay while SIP is mainly using RFC 2833. WellSC 5900 takes care of the conversion. Beside the SIP to H.323 conversion, WS6500 can also support SIP to SIP, H.323 to H.323 call without any limitations.
    http://www.welltech.com/product_e_2e.htm
  8. Wakky
    Jun 25, 2007
    ok... thx
    I think the best choice that i have is to sell the the equipment and buy a SIP gateway.
