3CX iOS 10.3
Discussion in 'iOS' started by Jmelvinbath, Apr 27, 2017.
  1. Jmelvinbath
    Apr 27, 2017
    Everything works fine if i have the 3CX app open. The second the app closes, screen sleeps, lock screen/home screen etc, the 3cx app seams to disconnect and never rings unless i have the app open already.
    Have to connect via tunnel when out of office for it to work.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,480
    67
    How you configured your PBX in order to handle push to your iOS? I mean, which version is your PBX, is free/pro, linux/windows, if you installed some certificates, properly setup extensions, performed a firewall checker...
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,325
    253
    any time i have this issue after an update, I send new provision email to user to apply to their softphone.
  4. GBC_James
    Feb 3, 2017
    61
    6
  5. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    12
    Hello @GBC_James ,
    Make sure that you have "Enable PUSH for smartphones" under specific extensions.
    Thank You
  6. GBC_James
    Feb 3, 2017
    61
    6
    thanks for replying,
    I can confirm that "Enable PUSH for smartphones" is selected
  7. Marios Neophytou
    Mar 1, 2016
    258
    12
    Hello ,
    As you mentioned on another thread you've deleted this : C:\ProgramData\3CX\Instance1\Bin\Cert\Apple\version.txt .
    Go to the same location and make sure that " aps_production.pfx " exist and inside " version.txt " the version number is 60904
  8. GBC_James
    Feb 3, 2017
    61
    6
    Yes, I can confirm both of those (see attached)
  9. Marios Neophytou
    Mar 1, 2016
    258
    12
    Perfect. Send a new welcome email on the phones and make a test call to see if this solve your issue.
    Thank You
  10. GBC_James
    Feb 3, 2017
    61
    6
    I am sorry to say the issue is not solved. The problems remain exactly as described above.
    With the phone locked, or the app minimised, no call comes through. Calls are received only when the app is open.
    On the third attempt we just tried, the call came through on the locked phone roughly 3 seconds after the calling phone hung up.
  11. GBC_James
    Feb 3, 2017
    61
    6
    Just to make this worse, we have been dialling and dialing, testing over and over again. (about 20 times)
    4 times the call came through after the caller had hung up, while the app was minimised (background)
    A call came through once while the phone was locked
    During all these test calls, no changes were made to anything. so it's crazy. the fact that 1 call eventually woke up the phone up seems to indicate push is kind of working.
    Frustrating.....
  12. Marios Neophytou
    Mar 1, 2016
    258
    12
    I have send you a P.M
