Solved 3CX IOS Old Version
Discussion in 'iOS' started by Kamoba, Mar 23, 2018.
  1. Kamoba
    Mar 23, 2018
    5
    Hi Everyone,
    I can't find an ipa file of 3CX app for my Iphone 4 :rolleyes:.
    Can you help to find it?
    Thank you!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Hi @Kamoba
    Unless you kept it on one of your old iPhone backups made using iTunes, there is no chance to find an old 3CX client, unfortunately.
  3. Kamoba
    Mar 23, 2018
    5
    Grrrr... :mad:
    Ok thank you!
