Solved 3Cx IOS working but getting timeout
Discussion in 'iOS' started by Joao Custodio, Feb 15, 2018.
  1. Joao Custodio
    Feb 1, 2018
    7
    I have the 3CX system setup, firewall checker is all green and all works fine on the internal network, from the outside when I open the IOS app it registers and on the top right states "On Hook", if I try calling an internal extension it rings but under the user photo I keep getting error messages in the following order: "Connecting"... "Timeout"... "Connecting"... "Error 405".
    On the Management console Event log I can see the extension registered.
    Thanks in advance
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,438
    61
    Hi Joao
    Our PBX doesn't answer back with 405 (Method not allowed). Since you mentioned the error is shown under avatar, it means is related to the MyPhone server (which, also, doesn't reply with 405). So, our advice is to check the NGINX server logs to see if/why it response back with this code. If you don't see there the iOS client' request, then you have to check your network environment (for proxies, for instance) to figure out who intercept the request and why it answers back with 405.
    Regards
    vali
    Joao Custodio likes this.
  3. Joao Custodio
    Feb 1, 2018
    7
    Hi Vali_3CX,
    Thanks for the quick reply, I hadn't payed the right attention to our NAT configs, we had port 5001 NATed to a NAS file station, after changing it to the 3CX server all started working perfectly.
