3CX IP PBX recommendations
Discussion in '3CX Phone System - General' started by luckman212, Aug 25, 2008.
  1. luckman212
    Aug 25, 2008
    hello,
    I am going to be rolling out a small IP-PBX: 12 extensions, 6 DID lines, 3CX running on 2003 server and using a dedicated DSL line with QoS for the voip traffic. Phones will be Cisco or Polycom IP phones probably. I am located in New York City.
    I really need help with:
    1) what kind of internet line/router is best for this- my options are kind of limited to DSL line or T1 at this point. I don't know if there is some other kind of new technology for delivering Voip traffic that I dont know about??
    2) if there are any links to other forums that are more general voip, not necessarily 3cx specific I would love that too.
    3) I would love some recommendations for the company who can provide the SIP termination as well... I am using CallCentric now but I am always open to other opinions...........
    thank you so much
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello luckman212,
    it's your first topic
    so I hope you found 3CX useful as I found it
    You can find all data you need in
    http://www.3cx.com/support/
    in IP Phones I think all of them are good
    but in ata gateway and voip providers you have to choose carefully
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Personally i would recommend Aastra handset as they (from what i've tested) have much better sounds and unit displays than Snom - and are more customisable with 3CX than Polycom.
