3CX iPhone App and Broadview VOIP using Mital 5330 phones
Discussion in 'iOS' started by msi, Dec 2, 2012.
  1. msi
    msi
    Dec 2, 2012
    Does anyone know if the 3CX iPhone app will work with the Broadview VOIP system?
    Broadview uses a propitiatory solution using Mitel 5330/5360 phones
    11,123
    330
    Re: 3CX iPhone App and Broadview VOIP using Mital 5330 phone
    If it does not use SIP,and Proprietary doesn't sound promising, then it won't work.
  3. StefanW
    Jun 2, 2009
    1,222
    93
    i would advice you to use to an PBX which follows standards, like your 3CX Phone System.
    This will give you all the flexibility in end handsets and you can choose what you like to use.
    Like your 3CXPhone
