3cx is logging off spontaneously
Discussion in '3CX Phone System - General' started by rebox, Aug 23, 2011.
  1. rebox
    Aug 17, 2011
    I have installed 3cx V7.03.775 on my system and everything is running fine except that 3cx is logging off spontaneously every few hours.
    I can’t find any setting or option in the program to prevent the automatic logging off. Also on internet I can’t find anything regarding this issue.
    Is there a setting I overlooked or what can I do to switch off the automatic logging off?
    Thanks,
    Paul
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Hi Paul,
    3CX version 7 is a very old build, any particular reason why you are using such an old one? You will find little help on it. My suggetion is that you upgrade to version 10.
