3cx & isdn card
Discussion in '3CX Phone System - General' started by manolo, Jul 17, 2008.
  1. manolo
    Apr 21, 2008
    7
    hi,
    how can I make a call from 3cx voip client to outside number over ISDN card
    I have PC with 3CX Phone System for Windows, and Asuscom ISDN P100 card conected to ISDN NT BAR (2ch) on the same PC.
    Thx,
    Manolo
  2. manolo
    Apr 21, 2008
    7
    I found :(
    You have to use an ISDN gateway such as a Patton if you want to connect a gateway. You can not use an internal ISDN BRI card.
    is this true?
  3. Stuck101
    Jul 15, 2008
    30
    You are correct, 3CX does not support any internal cards, only external gateway devices.
    I have a few Dialogic boards left from our old televantage system if anyone is interested......CHEAP :lol:
