3cx issue to upgrade to 15.5.0
Discussion in '3CX Phone System - General' started by sei, Apr 28, 2017.
  1. sei
    sei
    Aug 3, 2010
    Hi everybody,
    I'm using 3cx pro 15.0.0 (15.0.629..) on OHV Vps Linux version.
    I want upgrade to 15.5.0, I'm trying to use (without success) this ways:
    - upgrade via management console (upgrade button)
    (response: nothing to upgrade)
    - via ssh using:
    1. wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
    2. apt-get update
    3. apt-get upgrade 3cxpbx
    (response: 3cxpbx is already the newest version)
    what I'm mistaking?
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    15.5 is just in Alpha for the moment...
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,766
    277
  4. sei
    sei
    Aug 3, 2010
    hi Jason, hi Cobaltit, thank you.
    well now I understand, but I do not understand why the dashboard partner on 3cx site license refers to 15.5.0. Probably the license is enabled for the new version, so I just have to wait ....
  5. Mike Cruz
    May 8, 2017
    Things I have noticed with 15.5 I cant black/white list IPs. The firmware update feature isnt working. On the yealink phone the phonebook is not accessible (I think thats my issue not 3cx)
  6. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Now if you follow that procedure you can update.
    The Alpha was in a different repository so yes - there was really no newer version in the release repo at the time you did apt-get
    Try now.. It will work. Tip check the blog post and scan closely the repository we advertise. If you see 3cxpbxbeta or something NOT 3cxpbx, then the repository has changed and you need to update sources.d.list
