3cx IVR with spa3102 fax detection!
Discussion in '3CX Phone System - General' started by new4, Sep 4, 2010.
  1. new4
    Apr 7, 2009
    31
    Hi, to all :)
    I have a question, that maybe someone has already the answer to:
    Is it possible to receive a fax (through Linksys SPA3102-single PSTN line)
    which is set as an IVR by using the fax pass through feature?? :roll:
    I mean, the SPA3102 will operate as an IVR for ALL normal
    calls, but when a fax tone is detected, it will direct it to the
    fax machine (as described in the article below)
    http://www.3cx.com/blog/releases/3cx-fax-update11344/
    Thank ALL you in advance for your attention,
    Vassilis
    Rhodes island-Greece
