3CX licence Expired
Discussion in '3CX Phone System - General' started by Ross.Richter, Feb 1, 2013.
  1. Ross.Richter
    Feb 1, 2013
    Hi all,
    Im having an issue really with 5 phones all setup in a ring group,
    3 of them ring when all used to ring,
    if i de-register the working two the other extensions that didn't ring then do.
    I've even registered the other 2 phones to the working extensions base stations with the exact same result.
    the Licence for the 3CX Server has expired..
    would this have any effect on the amount of extensions that can now ring simultaneously?
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    It is not the 3CX license that expires, it is the Upgrade Insurance [UI] that expires. This means that you cannot apply upgrades to the system after UI expiry ... it's effectively frozen. This also means that you also can't download new 3CX software versions and apply that license to the system ...
    However, all of the functionality you have should remain intact after UI expiry ...
    Can you tell us what 3CX version you are running, and if you have done any software upgrades or reloads after UI expiry???
    Also - check the licensing page in 3CX and confirm that it is still showing that the system is licensed??
    And finally - what phones are you using?
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    In v11 ring groups do not work on the free version so if you have v10, v9 etc.... And UI expired and you upgraded to v11 youd be stuck using the free version ie no ring groups. Or if you were already using a free version and just wanted to upgrade youd loose the ring groups and what ever other features were available free in v10 or whatever prior version you were using etc.... Pleaser give a bit more informaiton on whavt version yuo have and license and the exact upgrade you attempted to make.
