Solved 3cx license issue
Discussion in '3CX Phone System - General' started by THCO, Jul 20, 2017.
  1. THCO
    May 16, 2017
    56
    11
    I was evaluating 3cx pbx edition 15.5.5. I decided to upgrade to the 32 sim call standard edition.
    I purchased the license through a reseller and gave them my existing serial number.
    Under settings i can see that my license now says 32 sim calls.
    On the dashboard it still says 8 sim calls. Also it has not unlocked the standard features.
    Do i need to wait a little more or am i missing sonething that I havent done.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    918
    146
    Seems like your reseller sohuld have been able to help you with this question but I would just restart the services or the PBX itself
  3. THCO
    May 16, 2017
    56
    11
    This has been solved.
    I went into settings and then to licensing and clicked on edit. Then I clicked on Ok without changing anything and it updated the license.
