3CX Limitation on outbound route
Discussion in '3CX Phone System - General' started by AldoLinares, Dec 28, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    I am trying to add some codes to the 3CX PBX to configure an outbound rule as suggested by the client:
    Example: *01 = XX XXX XXX XXXX it has to be 12 digits and the outbound rule its limited to 10 digits, it's there a way to change this limitation?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    there is a option under Outbound Rules named Calls to Numbers with a length of specifiy the length of your number i.e. digit of your number in your case 12 digits.
  3. AldoLinares
    Nov 12, 2007
    135
    I know that but what do you need to do if i want to add like a speed dial code *34 when someone dial that number automatically calls the full number more than 12 digits, this is very normal on another PBX not IP PBX but the older ones.
    I want to add codes like
    *12 = 12 digit number
    *23 = Emergency number X
    etc...
