3CX Limited Simultaneous calls
Discussion in '3CX Phone System - General' started by jmcairo, Jul 31, 2008.
  1. jmcairo
    Jul 31, 2008
    Hi!
    May i ask what will happen if 3CX accepts more than its limited simultaneous call to handle? For example i purchased the enterprice edition having 32 simultaneous calls but the calls offered to me during live production happens to be 100 calls. what will be the scenario? Thanks in advance for sharing your experties :p
    Regards,
    Jeff
  2. Anonymous
    Anonymous Guest
    On the 33rd call, the server status will report that the max. number of simultaneous calls allowed has been exceeded. Till one of the 32 calls terminates, no further calls will come in.
    Thanks,
  3. justin
    Feb 20, 2008
    79
    And no further calls can go out either.
  4. Anonymous
    Anonymous Guest
    The person is not notified... The only notification is in the server status log.
    I guess you make a valid point though and this should go down as a feature request.
