3CX line 1 blinking
Discussion in 'Windows' started by dennis76, Nov 19, 2012.
  1. dennis76
    Nov 19, 2012
    I'm using Asterisk. 3CX line 1 blinking, agent can hear the customer’s voice but caller unable to hear the Call Agent. anyone encounter this problem? pls help.
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    One way audio is common problem when something is wrong with firewall/NAT configuration.. start there
  3. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    There is a communication issue between the pbx and the phone
    The blinking light usually means the phone is "ringing" so it seems the rest of the setup did not complete.
    Usually when the call connects a 200 OK message is sent followed by an ACK message being received for that 200 OK. Coupled with 1 way audio I say you have some firewall issues.
    The easiest way to find out what is wrong on the softphone is to run wireshark on the computer the softphone is on and see what is missing.
