3CX Linux ISO - do NOT enable direct root login. Create "admin" user instead.
Discussion in 'Ideas' started by Silly English Kniggit, Mar 19, 2018.
3CX Linux ISO - do NOT enable direct root login. Create "admin" user instead. 5 5 4votes
5/5, 4 votes
  1. Silly English Kniggit
    Sep 13, 2017
    220
    90
    By default this is disabled on Debian for security. For some reason 3CX ISO enables this and only creates root user (no "admin" user). This leaves system vulnerable to brute force of the root account (as username is well known). There appears to be no account lockout, but if there was it would also make system vulnerable to DoS of root account via it being locked out.
    simply7 likes this.
  2. newuser1
    Nov 30, 2017
    25
    Is there a way to change the user from root to admin this after the system is already up and running?
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,752
    274
    Yep.
  4. TBWD
    Feb 28, 2018
    55
    12
  5. BrenttG
    BrenttG New Member
    Nov 17, 2017
    123
    31
    All you need to do is either disable ssh, or set the option so that it requires a key for root login, noone should be regularly logging into the shell in the first place.
    Also note that changing the SSH port does not fool most of the bots out there or the hackers, just the really dumm ones as far as brute force, the best solution is to have a firewall that supports ACLs in between your 3CX servers and the internet, and do not allow port 22, that way it can only be accessed from inside the network.
    NMAP/ZENMAP can find your SSH running on a different port in a matter of 30 seconds, so never rely on that ever, for any protocol, SSH, RDP, Telnet, etc. Changing the port number is just snake oil.
    Exposing any machine to the internet without a firewall or ACL supporting router is not best practice in regards to security, no matter which account it has setup on it, or how complicated your passwords are.
