3CX Linux - Waiting for network
Discussion in '3CX Phone System - General' started by Elvin Mammadov, Mar 13, 2017.
  1. Elvin Mammadov
    Feb 3, 2017
    42
    I have installed 3CX LInux and selected "Configure Network Manually to set a static IP address" by pressing ESC button during installation. But after installation completed, a message comes up: Waiting for network. But when I select DHCP, eveything is going okay. I have tested it both in real and virtual machines. There is active internet connection though. In our network, we have disabled DHCP and assign ip addresses manually. Why this message comes up and prevents me for next steps?
    #1 Elvin Mammadov, Mar 13, 2017
  2. jmr
    jmr
    Jul 17, 2015
    Assuming Hyper-V and installing from the ISO?
    It drops the network config on the first reboot, you just need to boot in recovery mode, and add it back in to the config.
    Was tearing my hair out for a while on this
  3. Elvin Mammadov
    Feb 3, 2017
    42
    I have burned ISO to cd and tested in PC and also either in vmware and dropbox, all of them gives the same message and waited for many hours, but nothing changed. I am really getting tired.
  4. jmr
    jmr
    Jul 17, 2015
    Have a snooze!
    Boot into recovery mode, then enter the root password
    Then
    vi /etc/network/interfaces
    You need to insert the IP as per below example
    auto eth0
    iface eth0 inet static
    address 192.0.2.7
    netmask 255.255.255.0
    gateway 192.0.2.254
    Then type
    shutdown -r now
    And it will start fine
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Elvin,
    If you are not familiar with vi command you can use nano /etc/network/interfaces. Also before do those changes please make sure that is a correct eth name/number of your network interface.
    Helpful commands just in case:
    ifconfig
    As mentioned above by jmr
    and then
    service networking restart or shutdown -r now
    I hope the above is useful to you. Also please let us know if it works for you or if you require any further information.
