3CX Log in Error Message
Discussion in '3CX Phone System - General' started by Divyesh, Apr 25, 2017.
  1. Divyesh
    Apr 21, 2017
    20
    After restarting the server and logging in with admin credentials, I get the following error message. Has anyone encountered this before?
    In house server on v12.0.4.1311.996
    Thanks.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Divyesh,
    Did you try editing the extension or going to Settings/Phones Provisioning? This error is due to older service pack from which the system was updated. To solve this issue you need to take a full back up of your system, then uninstalled, install latest exe from website here https://www.3cx.com/downloads/3CXPhoneSystem12.exe
    I would also recommend upgrading to v15 which addressed all those issues.
  3. Divyesh
    Apr 21, 2017
    20
    I've not tried editing anything along those lines. Its on SP6 as far as i'm aware.
