3CX log to Eventlog
Discussion in '3CX Phone System - General' started by Spyklee, Nov 12, 2010.
  1. Spyklee
    Nov 1, 2007
    45
    Is it possible to synchronize the 3CX log to the default Windows Eventlog?
    We've got a monitoring agent running on the event log. Currently we had an issue with a queue not registered (some how) and we're not able to monitor this automatically.
    Please advice.
    Cheers! Eric
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    HI,
    This is not possible, we should be look at why the queue failed rather then when it will fail again. If you havent restarted the PBX and it happened recently, please generate the support info and pull out the 3CXquemanager.log in here and make sure you use the code and /code tags.
