3CX Log Viewer Install?
Discussion in '3CX Phone System - General' started by JCarnes, Mar 9, 2017.
  1. JCarnes
    Apr 25, 2016
    24
    According to the 3CX Log Viewer guide here:
    https://www.3cx.com/blog/docs/3cx-log-viewer/
    It states "The 3CX Log Viewer can be downloaded and installed directly from the 3CX Management Console."
    Maybe we're just overlooking something, but we can't find where exactly this is listed in the 3CX Management Console. Where exactly is this supposed to be found?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,353
    535
    Hello @JCarnes
    Please note that this guide is for previous versions of 3CX PBX. It does not apply for V15. In V14 you can download it from the support tab on the top right of the screen.
  3. JCarnes
    Apr 25, 2016
    24
    Are there separate instructions for v15?
  4. YiannisH_3CX
    May 10, 2016
    7,353
    535
    No as the log viewer is not available from the V15 management console. The log viewer from V14 however can be used for v15 logs the same way.
  5. JCarnes
    Apr 25, 2016
    24
    Thanks for the info. I downloaded the log viewer Zip file directly from the Guide and am now able to access the log files (had to figure out where the .blrec file was stored). I am now able to use the log viewer, and it is very helpful. I would recommend updating guide for v15 users if at all possible.
