3CX Log Viewer
Discussion in '3CX Phone System - General' started by RussRiopelle, Oct 17, 2014.
  1. RussRiopelle
    Feb 4, 2014
    38
    Where can I download the 3CX Log Viewer. From what I have read here it is supposed to be in 3CX Phone System Updates/Other Updates but I do not see it there.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi Russ,
    What version of 3CX Phone System are you running ?
    Are you accessing the console in web mode or app mode? if web, check in app please.
  3. RussRiopelle
    Feb 4, 2014
    38
    I am using Version 12 with all the updates.
    I found it in Updates/Other Updates and it says it is up to date.
    Just where is the file so I can run it???
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    It is located in C:\Program Files\3CX PhoneSystem\Bin\Support\3CXBinLogViewer
  5. RussRiopelle
    Feb 4, 2014
    38
    Thank you very much....have it...... :D :D :D
