3CX Mac Softphone
Discussion in '3CX Phone System - General' started by Ray, Feb 7, 2015.
  1. Ray
    Ray
    Aug 18, 2014
    Having some issues with the 3cx Mac Softphone.
    Ranging from not registering...even after successfully registering the first time....to the phone not ringing when called.
    Anyone else having these issues?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    no issues here - using v12 SP6.
    You do not mention what version of the PBX you are using... or version of the softphone.
  3. Ray
    Ray
    Aug 18, 2014
    Details, details.... :D
    Version 12 SP 6.1
    Mac Softphone version: 1.0.75 alpha
    All my users login to the network via VPN, and all the PC platforms have no issues whatsoever. Mac users however have not been able to get the softphone to work at all. They are all on Yosemite.
    Any clues on where to start looking?
    Thanks in advance...
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Hi Ray
    If it's not a matter of privacy (IP's, passwords) please attach 3CXPhone's sys.log (in Documents/3CXPhone/Logs). Or, open a ticket to our tech support. Or, if you prefer, you may send me by PM an email address and I will send you an updated, test version, of the 3CXPhone.
    Regards
    vali
  5. Ray
    Ray
    Aug 18, 2014
    Vali,
    PM'd you and attached the log file.
    Thank you.
    ~Ray
    • sys.log
      File size:
      88.8 KB
      21
