Solved 3CX mail configuration
Discussion in '3CX Phone System - General' started by mahmoud, Mar 12, 2017.
  1. mahmoud
    Mar 12, 2017
    hello gents
    i have install Linux 3cx iso hosted on ESXi 6.5 and i have one issue i couldn't fix, i checked all the posts related to this subject but nothing happen
    the problem is configuring Gmail SMTP in the 3cx Managment panel it always give this message
    " The remote certificate is invalid according to the validation procedure"
    and i tried to configure other mail server such as Hotmail or our exchange but i couldn't make it work
    could you please help me on this
  2. andreaschr
    Oct 26, 2015
    91
    6
    Hi Mahmoud,
    Can you please do the following.
    Login on the Machine and perform Update&Upgrade
    execute the following CMDs from the terminal
    sudo apt-get update
    sudo apt-get upgrade
    Let us know if that works for you.
    P.S do you have anything that sits in between the PBX and the SMTP Server(ex. Firewall), that's replacing the certificate?
    mahmoud likes this.
  3. mahmoud
    Mar 12, 2017
    thanks a lot
    its work for me
  4. Steve Li
    Apr 4, 2017
    Hi, I'm having the same issue but with my own mail server. I have tried the apt-get update and apt-get upgrade but still having the same errors. I am positive that my mail server is working as it works with other services. I do have a router between the internet and the mail server but it is not replacing the certificates. I am running the latest 3cx linux version.
