3cx management console login blank screen
Discussion in '3CX Phone System - General' started by Greaterfaith, Nov 19, 2014.
  1. Greaterfaith
    Nov 19, 2014
    In the past, I had no problem to login to my management console from my PC. I've tried to login in my Management console and now I had a blank screen (using firefox). I tried to type http:// ###.####.###/ management/Main Form.wgx and I still get a blank screen. please advice ;)
    11,277
    360
    If I have to use a browser, such as remote access (via VPN), I use http://XXX.XXX.XXX.XXX:5000/MainForm.wgx
  3. jackfinn
    Nov 19, 2014
    6
    I use http://myserverip:5000/management some times I need to hit refresh because there seems to be a delay and times out but the second time it works
  4. Markademus
    Nov 20, 2014
    That has happened to me in the past, try the 'compatibility mode' in your browser,,,,,,
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Go to the system and log in using the 3CX Management Console. Once in, look at the IP Blacklist as the system from which you are trying to use, has likely been blacklisted. This can occur if too many unsuccessful attempts to login have occurred or even if you have the client softphone installed and it is failing on the registration attempts due to failed authorizations.
    You can also use a different system for the web login if needed.
