3CX missing from App Store??
Discussion in 'iOS' started by musicloverlch, Aug 18, 2014.
  1. musicloverlch
    Jul 29, 2014
    5
    I can't find the 3CX app in the app store. When will it be back? :(
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi, we had an issue with the app store last few days but it has now been addressed, and you can find 3cxphone back. Check.
