- Joined
- Oct 17, 2017
- Messages
- 48
- Reaction score
- 12
The mobile clients (iOS, adnroid) should handle the Roaming between different networks. If I change during a call the location from WIFI internal to outside (go out of the company). the mobile phone connect to 3G/4G and lose the active call. It should be possible also otherwhise (3G/4G to WIFI).
I made some tests:
- Wifi internal only -> Connection to 3CX and communication is possible
- 3G/4G only -> Connection to 3CX and communication is possible
- Roaming from Wifi to 3G/4G during a active call. -> Communication will be lost
- Roaming from 3G/4G to Wifi during a active call. -> Communication will be lost
I made also some tests with whatsapp call, skype, and cisco jabber. the other applications/solutions can handle the hopping/roaming.
this behavior is common. the customers move during a call through different networks an will be still connected in a active call.
I made some tests:
Upvote
76
