3CX mobile config for callcentric sip
Discussion in 'iOS' started by coulibbaly, Oct 17, 2012.
  1. coulibbaly
    Oct 17, 2012
    Can you please give me the config to use 3CX with callcentric sip account?
    Regards
    Seydou
  2. hgonzale
    Nov 9, 2012
    It's easy, use the follow values:
    user: your username 1777xxxxxxxxxxx
    password: your password
    use as: Sip account
    local pbx ip (optional) callcentric.com
    external pbx ip (mandatory): callcentric.com
    pbx port 5060
    stun server: blank
    proxy: blank
    local sip port: 5065
    first rtp: 4000
    nat helper: on
