3cx mobile existing contacts dial 0
Discussion in '3CX Phone System - General' started by scrollz, Aug 13, 2015.
  1. scrollz
    Jul 24, 2015
    11
    we have dial a '0' to get an outside line - which is fine.
    i entered all our contacts into the company phone book and prefixed a '0' onto the number as i added them.
    3cx phone has pulled all other contacts from the mobile phones phone book - BUT these are not prefixed with the '0' so i cant use them contacts in 3cx
    so, is there a rule that would get me around this? or is it easier/better to remove the '0' for a line ?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Unfortunately no prefix can be automatically added to the phone contacts imported, please post this as a feature request on 3CX Ideas : http://www.3cx.com/ideas
    In the meantime, you will need a matching outbound rule for those contacts numbers.
  3. leejor
    10,850
    299
    Depending on where in the world you are located, it may be easier to add a prefix to all of the contacts (or most) in your phones directory, a prefix that can be used by your mobile provider and be easier to work with in the 3CX outbound rules.
    For instance, in North America, many mobile providers will accept a local or national number, with, or without a "1" as the first digit. If this worked with you provider you could prefix all of your contacts with a 1, then, in 3CX, you could create a rule that can deal with any number starting with 1 and is 11 digits long. The 1 can be stripped and a zero prefixed. You can also specify that this rule is only used by certain extension numbers if you wish.
