3cx Multi Location Options
Discussion in '3CX Phone System - General' started by Chris50, Oct 23, 2017.
  1. Chris50
    Oct 23, 2017
    I'm looking at theoretical setup of 3cx in a multi location business. 10 locations ranging from 3 users to 80 users each. Not a call center but high volume usage. While a single central 3cx server would help minimize maintenance and config, I'm not sure it would be best bet for this design.
    Biggest concerns are limit of 50 shared parking (yes, that would be reached), very large number of ring groups (some locations would have 6+), different hours for some locations, etc.
    Does anyone have recommendations for single central server / vs location specific server? Network connection between branches is 10+ Mb so no issues there.
  2. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    735
    113
    I don't really see what recommendations anyone can make for a single server given you already understand there are limitations that don't fit your business needs.
  3. Chris50
    Oct 23, 2017
    Just double checking I'm not missing any viable workarounds that the more experienced could point out. I continue to learn more about VOIP daily and if/when this project becomes reality, I'll most likely reach out to a more qualified implementer.
  4. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    It's up to you finally, cost of several 3CX instances is higher than one larger license, but probably you don't have alternative. You may bridge your 3CX instances, if needed, via Internet or private VPN.
