3CX Music On Hold Seperate For diff extentions
Discussion in '3CX Phone System - General' started by qaisdev, Jul 8, 2008.
  1. qaisdev
    Apr 7, 2008
    33
    Is there a possibility of having a diffrent music on hold tune for a specific extention.
    I want to give a specific DDI a diffrent hold music.
    Thx for the help...
    Kinds Regards
    Qais
  2. justin
    Feb 20, 2008
    79
    Not at present I'm afraid.
  3. qaisdev
    Apr 7, 2008
    33
    Thx for the reply...
    So i will have to find another way.
    I am planning to put another 3cx server and direct a specific number to this secondary server.
    This way i can change the hold music.
    Cheers
    Qais
  4. darrellchapman
    Nov 26, 2007
    268
    Is it possible to use multiple Digital Receptionists for music on-hold? Have the music as a greeting and the timeout to forward to another DR which loops back to the first. The question then is how do you get the call out of the loop?
  5. Anonymous
    Anonymous Guest
    Couldn't you use something like Audacity (http://audacity.sourceforge.net/) to simply merge two or more tracks together?
    Thanks,
  6. Anonymous
    Anonymous Guest
    In that case, this is a feature request and should be posted to that forum.
    Thanks,
  7. Thona
    Aug 10, 2007
    54
    Maybe he is not talking about "Music".
    One extension could be a support line, and while waiting you could read instructions to the user what to keep ready. I had that once at a provider. Definitly a more rarely used feature, but a used one nethertheless ;)
  8. francesco
    francesco New Member
    Jun 23, 2008
    102
    yes, is it possible!
  9. francesco
    Jun 23, 2008
    102
    yes,
    you can specify a different music for a different queue.
  10. darrellchapman
    Nov 26, 2007
    268
    francesco,
    Can you provide a link or instructions on how to accomplish this please?
  11. francesco
    Jun 23, 2008
    102
    you can set welcome message and music while waiting for an answer
  12. darrellchapman
    Nov 26, 2007
    268
    Thanks. You guys are brilliant!
  13. francesco
    Jun 23, 2008
    102
    I am happy for you :lol: :lol:
  14. qaisdev
    Apr 7, 2008
    33
    Hi Matt,
    Sorry was not in the office for a long time now.I will have a go and will let u know if it works.
    Thx fot the help.
    Qais
