3CX Music On Hold
Discussion in '3CX Phone System - General' started by lexd123, Mar 4, 2014.
  1. lexd123
    Mar 4, 2014
    Hi All!
    I was given the task to change the onhold music on a clients 3CX Phone System. I thought this will be pretty straight forward, but it wasn't.
    The problem which i find strange is that when i log onto 3CX > Settings > General > Music on Hold (and press play button the on hold music section). The music that is played on the phone is completely different from the music being played when I am placed on hold from the phone.
    Also I am unable to locate the onhold.wav file on the server?
    Please advise how the on hold music can be changed on the 3CX phone system.
    Thanks!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
    What kind of phones... Is it possible the phones have their own moh file?
  3. lexd123
    Mar 4, 2014
    The phones are Yealink SIP-T38G.
    The hold music is currently the same as (which is the default 3cx music)
    http://www.youtube.com/watch?v=F4eVsWlxm1M
    but when i hit play from the 3cx server, it plays something different. This is what i dont understand?
  4. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    onhold is located in
    C:\ProgramData\3CX\Data\Ivr\Prompts
    General>Music On Hold is literally for on hold.
    To change the music while a customer is in a QUEUE can be set on the queues under "Other Options"
  5. lexd123
    Mar 4, 2014
    Thanks alot for your response.
    I have sucessfully located the onhold.wav in the directory you mentioned above and it is the music that i wanted to hear.
    I still find it strange that the 3CX console play button, plays something that is completely different when i enter the extension for it to play...
