3CX MyPhone and Outlook 2013 x64
Discussion in '3CX Phone System - General' started by egiblockDM, Apr 25, 2013.
  1. egiblockDM
    Apr 22, 2013
    39
    nothing but errors from the 3cx myphone integration with outlook 2013 x64. anyone else testing this ?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    802
    45
    I integrated the 3CX MyPhone with Outlook 2013 x86 on a Windows 8 Pro x64 OS and it is running without any problem.
    So I think the 64 bit version of Office 2013 does not (yet) support the 3CX MyPhone plugin? Maybe v12 does.
    BTW: You know the difference between the x86 and x64 editions?
    Running the x64 (64 bit) edition also requires an x64 Windows edition. The advantages of Office x64 is a bit better performance. Disadvantage is that it doesn't support most third party plugins and add-ons. Microsoft actually discourages the use of the x64 editions. So unless you're absolutely sure you need an x64 edition, you should choose x86 (32 bit).
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    I am using Win7 x64 with Office 2013 x64 and it is working just fine.
    Are you logged in as a local admin on the computer (domain or otherwise - but administrative rights?)
    How about right clicking on the installer and saying run as administrator?
